October 10, 200521 yr Hi, I have had a 2005 Rev 3 250cc for about 4 months now and have been plagued with pinking problems for a long time. Before I start playing with the carb can someone tell me the standard setting for the mixture screw(mine is just over one turn out) and what size the standard jets are for this bike? It also seems the engine is hunting for fuel If they are ok would adding octane booster to the petrol help cure it. Thanks in advance for any info Regards AS
October 10, 200521 yr On my 2003 250 the principal jet is 150 and the idle is 30. The engine runs well with the idle when the screw is unscrewed of 1,5 turns.
October 10, 200521 yr my 05 250 rev3 mixture screw is just over one turn out,i use shell optimax mixed 70ml oil to 5lts of petrol and it runs fine this was set on delivery
October 11, 200521 yr Author Cheers Guy's Thanks for the info, just proves once again what a friendly crowd Trials riders are. Best Regards AS Edited October 11, 200521 yr by Alshine
October 11, 200521 yr Author Another thing I should mention Re: my pinking problem is that I had another carb slide in the box of bits that came with my Rev 3. I now have slides with a 2.0 and a 3.0 cutaway.Anyone know which is the standard one.I could just try them to see the difference but the carb is such a B*****d to keep taking off. Any info once again greatly received. Many Thanks AS
October 13, 200521 yr I could just try them to see the difference but the carb is such a B*****d to keep taking off. <{POST_SNAPBACK}> Not sure how you're doing it but the Beta's carb is the easiest and quickest to remove and refit of any bike I've owned. To remove, loosen the two jubilee clips, pop the carb out of the boots, disconnect the fuel line and unscrew the top to remove the slide/needle (turn the carb, not the top) - it's off in less than a minute. Reinstalling is slightly trickier although it gets easier when you've done it a few times and a light coat of WD40 on the inside of the rubbers helps a lot. Reinstall the slide/needle, reconnect the fuel line then (this is the trickiest bit) get the airbox rubber on. Once done, push the carb back and inwards and it'll pop back onto the manifold boot. Tighten clips and the job's done! Once you've done it a few times it's possible to get the carb off, clean out, even rejet or adjust the needle height if so desired and get it back on in 5 minutes - I've done it myself between laps at a trial.
