markb21162 Posted January 18, 2016 Share Posted January 18, 2016 Hi all I've just got my 1st trials bike the loom has being cut looking for help to get the bike running it's a beta techno 250 1997 thanks mark Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted January 18, 2016 Share Posted January 18, 2016 I think you will need to give a bit more detail than "cut" if anyone is to offer sensible advice. Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 18, 2016 Author Share Posted January 18, 2016 (edited) Hi m8 there is some plugs on the loom and some cut off AV got a plug from the magneto then there is a brown/white wire and a red/white the there is a plug on the cdi then there is a single blue wire there is no plug on the coil it's got a black and a black/white then AV got a wee box which has a single yellow wire then there is the fan there is a green wire that comes from the thermostat that a think is an earth then a yellow wire hope that all makes sense thanks mark Edited January 18, 2016 by markb21162 Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 18, 2016 Author Share Posted January 18, 2016 If a could get a good wiring diagram a would m8 just can't get hold of 1 that u can read Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 18, 2016 Author Share Posted January 18, 2016 AV got most ov it done a think just not sure what wire from the kill switch go to the red/white and what the blue wire from the cdi is for and where the box with the single yellow wire is for Quote Link to comment Share on other sites More sharing options...
rgvlc Posted January 18, 2016 Share Posted January 18, 2016 Blue from CDI goes to frame / earth. Yellow lead from box connects to yellow from stator,( another yellow is split from this to power the fan circuit ) one kill switch wire goes to red / white the other goes to frame / earth Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 18, 2016 Author Share Posted January 18, 2016 Thanks m8 do u no what 1 from kill goes red/white Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 18, 2016 Author Share Posted January 18, 2016 Cool bud thanks that should be the puzzle finished al have a go at it tomorrow let you no how a get on thanks for the help and wish you all safe ridden Quote Link to comment Share on other sites More sharing options...
feetup_mostly Posted January 19, 2016 Share Posted January 19, 2016 Argh text speak. 1 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 19, 2016 Share Posted January 19, 2016 If you put your location on your post it may be there is someone local who could help or advise a good local dealer. Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 19, 2016 Author Share Posted January 19, 2016 That's the bike just about done just 1 wee thing left and a can't find it can't find the bleed nip for the clutch can some 1 help out with this Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 19, 2016 Author Share Posted January 19, 2016 https://www.google.co.uk/imgres?imgurl=http://trialstribulations.net/images/products/R3clutchslave.jpg_1024x768.jpg&imgrefurl=http://trialstribulations.net/index.php?main_page%3Dproduct_info%26products_id%3D1501&h=768&w=1024&tbnid=vMoDARBzhCQqnM:&docid=aa9FAD29G74LrM&ei=vLqeVonCBISAUYTXq6AC&tbm=isch&ved=0ahUKEwiJkOGm-LbKAhUEQBQKHYTrCiQQMwgjKAcwBw Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 19, 2016 Author Share Posted January 19, 2016 (edited) http://www.motomerlin.org.uk/ekmps/shops/motomerlin1/images/brake-union-bolt-with-bleed-screw-gas-gas-pro-clutch-392-p.jpg Is that the bits ur talking about m8 Edited January 19, 2016 by markb21162 Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 19, 2016 Author Share Posted January 19, 2016 Thanks m8 need to get 1 like that the 1 it's in has not got the nipple on top it's the same as the 1 from the brakes Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 19, 2016 Author Share Posted January 19, 2016 Just that to get bleed the back brake and find out how the cdi sits in then that's me ready to start kicking it over Quote Link to comment Share on other sites More sharing options...
