ric h Posted February 26, 2016 Share Posted February 26, 2016 Does switching from ajp to bk master cylinder make for a significantly lighter clutch pull? My 2011 Ossa has a very stiff clutch compared to some other models.Anyone? Quote Link to comment Share on other sites More sharing options...
baldilocks Posted February 26, 2016 Share Posted February 26, 2016 It's the clutch pack thickness not the master cylinder Quote Link to comment Share on other sites More sharing options...
mazz46 Posted February 26, 2016 Share Posted February 26, 2016 Other way round a ajp better then braktec in my opinion? Quote Link to comment Share on other sites More sharing options...
canada280i Posted February 27, 2016 Share Posted February 27, 2016 It's the clutch pack thickness not the master cylinder Told ya! 1 Quote Link to comment Share on other sites More sharing options...
arnoux Posted February 27, 2016 Share Posted February 27, 2016 Agree Braktec and AJP internals the same. Look elsewhere for your stiff clutch. Did anyone put DOT4 in your mineral clutch and swell the seals perhaps? Or plate fibres too thick. Quote Link to comment Share on other sites More sharing options...
ric h Posted February 27, 2016 Author Share Posted February 27, 2016 Thanks for the replies.Nothing but mineral oil in it for sure.I'll have to pull it apart to check the height of the clutch plate stack. Quote Link to comment Share on other sites More sharing options...
canada280i Posted February 28, 2016 Share Posted February 28, 2016 If you lay the bike all the way over you can take the clutch cover off without draining the oil, also makes it easier to centre the spring when putting it back together Quote Link to comment Share on other sites More sharing options...
ric h Posted March 12, 2016 Author Share Posted March 12, 2016 (edited) Ok,lapped the friction plates to get the stack to 9.75 from 9.88.Went together really easily.The lever pressure is VERY nice now,but the clutch still drags badly.I probably rushed it a bit bleeding the system because my fluid level was low.I'll have a couple of beers and bleed it again tomorrow.Fun tinkering! Thanks everyone.Esp canada280i Edited March 12, 2016 by ric h Quote Link to comment Share on other sites More sharing options...
