john b Posted March 4, 2016 Report Share Posted March 4, 2016 Hi Ive covered rim size on a previous post, but thought I would ask the remaing (at the moment) questions in one go 1 - Sprocket size Its a 4 speed engine - unsure of any internal gearing changes. What the best combination of sprocket sizes ? Also- chain, 428 ? 2 - Wheel offet Im about to get new rims built onto bantam hubs Rear (using a widened swinging arm and engine offset 8mm) - I think needs no offset ? Front - I think 6mm offset to brake side ? 3 - Chain tensioner Any advice on best type ? may think of more ! cheers John Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted March 4, 2016 Report Share Posted March 4, 2016 Hi Ive covered rim size on a previous post, but thought I would ask the remaing (at the moment) questions in one go 1 - Sprocket size Its a 4 speed engine - unsure of any internal gearing changes. What the best combination of sprocket sizes ? Also- chain, 428 ? 2 - Wheel offet Im about to get new rims built onto bantam hubs Rear (using a widened swinging arm and engine offset 8mm) - I think needs no offset ? Front - I think 6mm offset to brake side ? 3 - Chain tensioner Any advice on best type ? may think of more ! cheers John Have you changed the crankshaft sprocket ? you should. 12 tooth crankshaft. 12 tooth gearbox. 60 tooth rear wheel on a 428 chain but some use 420 to help with clearance. I used Whitton hubs which are 17mm offset from brake face front and 34mm from inner sprocket face rear but i dont know if bantam would be same. Chain tensioner depends on where you mount it any aftermarket universal one should do. Quote Link to comment Share on other sites More sharing options...
dave_t Posted March 8, 2016 Report Share Posted March 8, 2016 Hi John Ref chain tensioner get one from Jim Pickering (Drayton), it fits at lower rear engine mounting point (actually bracket to frame bolt), it uses a longer bolt has a roller instead of a pad and is well out of the way, they are made to fit Drayton frames but to fit to my modified Bantam frame I just used a thinner nut between roller and bracket and removed a small amount from allen bolt head one of those jobs where thinking time is more than doing time. I originally used a universal one but it got continually bent or pad filled with mud and stones. Quote Link to comment Share on other sites More sharing options...
john b Posted March 11, 2016 Author Report Share Posted March 11, 2016 Cheers dave do you have a contact number ?ive searched on internet but cant find cheers john Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 12, 2016 Report Share Posted March 12, 2016 draytonframes@internet.com Quote Link to comment Share on other sites More sharing options...
john b Posted March 12, 2016 Author Report Share Posted March 12, 2016 Cheers ! John Quote Link to comment Share on other sites More sharing options...
dave_t Posted March 12, 2016 Report Share Posted March 12, 2016 John Jim Pickerings phone no is 07850 836571 Quote Link to comment Share on other sites More sharing options...
beesa71 Posted March 12, 2016 Report Share Posted March 12, 2016 Is there a Drayton website? I can't find one so thought I'd ask. Or, other than at shows and events, is there anywhere his products can be viewed? Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted March 13, 2016 Report Share Posted March 13, 2016 Is there a Drayton website? I can't find one so thought I'd ask. Or, other than at shows and events, is there anywhere his products can be viewed? You cant move for them at trials round here Quote Link to comment Share on other sites More sharing options...
laird387 Posted March 14, 2016 Report Share Posted March 14, 2016 (edited) Is there a Drayton website? I can't find one so thought I'd ask. Or, other than at shows and events, is there anywhere his products can be viewed? Hi, In ORRe, our digital magazine, you'll find plenty of details, including a test session with Mick Grant's Drayton copiously photographed, plus many photographs of them in action in the various classic trials around the country that have been 'Photoreported' In the next issue (due out shortly) you will find images of some of the Draytons in action at Kinlochleven this year; Enjoy Edited May 25, 2016 by laird387 Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted May 25, 2016 Report Share Posted May 25, 2016 Is there a Drayton website? I can't find one so thought I'd ask. Or, other than at shows and events, is there anywhere his products can be viewed?Just wondering did you buy a Drayton in the end? Quote Link to comment Share on other sites More sharing options...
