October 22, 200521 yr My brother has just had his frame welded by john lampkins.he noticed that it was leaking fuel and on futher inspection there was a crack found in weld under fuel neck plastic trim on right hand side of tank has any one else had this problem? bike is a 2005 rev3
October 22, 200521 yr yeah, my 04 270 leaked on the left hand side next to the weld that incorporates the fuel tank, it might just have been a poor factory weld, or cracked through heavy use, but lampkins took the bike away , welded it and returned it in a few days, very good service in my book.
October 29, 200520 yr Author Dont belive it but my mates 04 270 rev3 frame as cracked in the same spot as my brothers?
November 14, 200520 yr I have got a 2000 model 250 which got cracks on both sides of the frame, my friend has the same model bike with exacly the same weld problems, easily tig welded just steam clean the tank first!!!! I always put it down to the bike doing the odd cartwheel, but who knows? p.s. I also had a problem with the original swingarm that broke along the weld, fitted the 02 type, much better.
