Marcelle 250 Barrel.
Hi guys,i've now looked into the trailer load of bits and pieces i bought and i've now found a 932 concentric and what i believe is an old 'Jonny
burns' Motox develoments barrel and two heads (350/360 c.c.?).So it looks like i have a bunch of pre '70 scrambling gear.
Excuse my ignorance,but did i see in the press a fella trialing a big bore villiers? (was his first name Maurice?)
I think i might try and stick it on top of a 32a in an old '62 dot frame i've got, and see what happens.(Any ideas about carbs and jetting and exhaust bore for that.
Life's fun.many thanks.
A few guys locally have tried these but not one of them has been a sucess sadly and they have all reverted to 250 barrels. Those big bore conversions were a nightmare to set up and get running right. No real world benifit.
  • Replies 32
  • Views 20.8k
Most Popular Posts
  • Hello Tsf, tthe Norton is not rigid, in fact it is a Noriel with a model 19 engine and burman gearbox, Norton fork, cub hubs, I bought it a the Talmag well 12 years ago. Its terrifying bike to ride b
  • old trials fanatic
    old trials fanatic
    Personally i would use a 26mm Premier Amal concentric.
  • villiersprodigy
    villiersprodigy
    Marcelle barrels were used for both scrambling and trials.If it came with those size carbs it stands a chance it may have been used for scrambling. OTF is correct by saying that a 26mm is best for tr
Hi Garyhib,
I had a DOT Demon MX or scrambles bike which had a John Burns/MotoX Motors 360cc conversion fitted. The stroke is 72mm so same as the std Villiers,the bore is increased to obtain the extra capacity. This requires the crankcase mouth to be enlarged so really for those cases it is a one way conversion, if you have cases that fit the cylinder then these will have been enlarged to suit.
My bike went rather well with great pulling power, noticeably more than a 250 though not quite up to CZ or Husqvarna speed. Engine was Villiers gearbox, Alpha crankcases and crank with Stefa electrics.
The downside of the conversion is weight, there is a lot of alloy in the barrel making it much heavier than say a Greeves square barrel, also because the design is Villiers based the transfer ports remain the same size so this possibly limits the engines potential.
If you have the parts though why not build it and enjoy something a little different Maurice goes well enough on his bike which uses a James or FB type frame.
The old NCB wellies/Dunlop trials boots.
Hi trialsrfun,
Nice to see Paul Jackson is still with us - how will he manage his bike with only one boot.................
Probably better than me with two boots....
Hi Gary and all reading this.
I would like to see a photo from your engine with the Marcelle barrel.
I believe that I have one on my Greeves. (will post a photo later)
Thanks.
Christian.
Hi Christian,
The MotoX cylinder & head are rectangular when viewed from above, wider left/right thanfront/rear. The fins at the upper part of the cylinder are wider than the lower ones exactly as on the picture above of Maurice riding his bike.
Hi all,Christian,the picture of Maurices barrel/head is the same as what i've picked up.The angles,spaceing, shape and height are spot on. Could yours be a 'Parkinson' or a DMW? I'm sure someone can tell you.All the best.
Hi Christian,
Your Greeves is very nice but I cannot identify the cylinder other than to say it is not a MotoX conversion, how does the engine performance compare to other Villiers bikes you may have ridden.
Hi Christian,
The Greeves is my spare bike when the Norton is out and it is a completely different riding( is it a surprise? ;))
Once I get used to brutalise the throttle when I need power, it works quite well, it is very soft at low rev's and almost unstopable, about power, it is not my Norton but I really love to ride the greeves (not as much as the Norton thou).
Compared to other Greeves I could test, there is a small lack of response at low revs.
There is something strange on this engine, the conrod is the short one , I believe from the 190cc Villiers.
Was it a modification they used to do??
I own this Greeves from 2005, and never saw one with the same barrel.
Hello Deryk, on the photo you posted the barrel seems wider and head fins arrangement is not the same.
Thanks for your replies.
Christian.
Edited by christian
Hi Christian the first type of engine similar to the one you have in the Greeves was 9E 197cc with a 5 1/4" conrod, when this engine was enlarged to 246cc the barrel base flange was increased in thickness by 1/4" to add strength because of the greater power output, this required the rod to be lengthened by 1/4" to 5 1/2" these were the A series engines 32a 34a 37a.
My knowledge of the alloy barrels is mostly Greeves, DOT, Ajax for the 197 to 225 conversion and late DMW.
Parkinson, Marcelle and others also made cylinders but these I am unfamiliar with, possibly someone with engineering connections could have produced one or more as well.
The last type of DMW cylinder was designed for use with the shorter 5 1/4" conrod, all Greeves and DOT barrels that I have come across use the longer rod as does the MotoX conversion that Garyhib has.
Irrespective of rod length the stroke remains the same at 72mm.
The porting in your cylinder appears to be very similar to the other Villiers fit barrels but without accurate measurements from known cylinders it is not possible to say. Often the greatest visible difference is the size/shape of the inlet port but maybe the biggest perfomance vaiation would be due to the type of head and compression ratio used.
Hope this helps.
Edited by trialsrfun
Hope this helps.
Hi trf, very good to read your interesting comments.
I have also , what I believe is a very late DMW barrel and head.
If I could find the time to fit it !!!!
The Norton is still going strong and is reliable, so there is no need to improve the Greeves for the moment.
Regards.
Christian.
Edited by christian
Regards.
Christian.
Is the Norton a 500T rigid Christian?
Its terrifying bike to ride but I like her so much.I think it is my last trial bike.
Edited by christian
