toetoe Posted August 24, 2016 Share Posted August 24, 2016 i have been trying to get my kickstart off today but it will not budge, any suggestions would be very appreciated, the bike is 2013, thanks. Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted August 24, 2016 Share Posted August 24, 2016 Unscrew the Allen bolt that secures the kickstart to the centre of the shaft about 2 turns. Then pull the kickstart out so that it presses onto the top of the bolt, this will extract the kickstart knuckle from the shaft. If its tight all the way unscrew the bolt a few turns again and repeat. Quote Link to comment Share on other sites More sharing options...
eddie1 Posted August 24, 2016 Share Posted August 24, 2016 Watch this great video by Jim Snell. Quote Link to comment Share on other sites More sharing options...
zuendapp Posted August 24, 2016 Share Posted August 24, 2016 One word of caution, I would not remove the water pump from the clutch housing, I normally put a tie wrap thru one of the bolt holes to make sure it doesn't come out of the housing. Also the kick start shaft seal can be damaged on removal / install. I am surprised that your bike is a 2013 that you haven't become a expert on side cover / clutch pack adjust / kick start repair yet ;-) Quote Link to comment Share on other sites More sharing options...
toetoe Posted August 25, 2016 Author Share Posted August 25, 2016 The first thing I did was to go to YouTube and I did what the Jim Snell video said but no chance, iv had it socking in wd over night but still no joy, as far as being an expert, iv had the bike for almost two years and haven't had any problems with the kick start, clutch or cover in fact except for the normal wear and tear its never let me down, thanks for the replies everyone, iv gone as far as my limited skill will allow me, luckily a mechanic friend has offered to help me out, I think that would be the best way forward. 1 Quote Link to comment Share on other sites More sharing options...
baldilocks Posted August 25, 2016 Share Posted August 25, 2016 I usually have to kick the bike over with the lanyard off. Compression to push against helps 1 Quote Link to comment Share on other sites More sharing options...
