September 10, 201610 yr Hi can anyone help. I have have Front headlight & rear light Fitted to my RTL. Can i use the Existing Wiring from the Engine to power the Lights. If so what Colours are they. Any Help with this would be much Appreciated. Dave. Edited September 10, 201610 yr by buzz white
September 10, 201610 yr Sorry, can't help with the lights, but just a bit of info, I think that's a 87. Edited September 11, 201610 yr by jj65
September 10, 201610 yr As far as I know you can only work lights if the bike is fitted with twin coils inside the flywheel,most Japanese imports don't have these.the wiring diagram in the manual will show you if you know someone that has one or there was one on one of the honda trials pages
September 11, 201610 yr As johnboy has said, apparently you need 2 coils, if your bike is one of the many brought in from Japan, it won't have the 2 coils, if it's a European one, it should have both. Edited September 11, 201610 yr by jj65
September 12, 201610 yr Here's another pic for you. Obviously mine is a jap import, so it's only got one coil.
September 16, 20169 yr Hi, this is not a problem to solve, you just add a coil and a voltage regulation (gasgas for my bike) Kcnarf. Ps: i'm very surprised that on a large forum than nobody gives the answer Edited September 16, 20169 yr by panerai
September 16, 20169 yr Hi, this is not a problem to solve, you just add a coil and a voltage regulation (gasgas for my bike) Kcnarf. Ps: i'm very surprised that on a large forum than nobody gives the answer Thanks Franck.
