September 17, 201610 yr Hi has anyone a step by step guide to fitting swing arm extensions on my ty175,like the ones shedworks sell.
September 17, 201610 yr what is the lenght of standard swing ar/m,i would like to measure mine to see if it's been done
September 18, 20169 yr Hi has anyone a step by step guide to fitting swing arm extensions on my ty175,like the ones shedworks sell. If you are talking about the weld-on extensions, I posted such a thing years ago and will look for the photos. In the mean-time, a brief sequence of events so you can decide if the job is for you; Remove the swingarm Cut off the first axle plate at the correct location and angle Prepare the first side for welding. I used double vee butt welds and manual arc Weld the first extension piece on Make a dummy spacer to replace the wheel, spacers, brake plate etc Fit the axle and spacer to hold the second extension piece in position Prepare the second side for welding, using the axle to make sure that the second extension plate is in the right spot to make the axle slots the same height, parallel with each other and the same distance from the swingarm pivot axle Tack weld the second extension in place Check everything is aligned properly Finish the welding Dress the welds back flat Make a longer brake tension link Extend the side stand a bit Move the brake arm forwards on its splines, or make a longer brake rod Bend the rear frame loop upwards a bit to miss the tyre on full compression Edited September 18, 20169 yr by feetupfun
September 18, 20169 yr what is the lenght of standard swing ar/m,i would like to measure mine to see if it's been done You can tell if this mod has been done without measuring by looking at the position of the axle slot relative to the shock mounts. I moved the slot 45mm rearwards and followed the same line as the old slots (not higher or lower). It is fairly obvious in my photos (above) A friend of mine did a similar mod but moved the slot less rearwards, and 5mm downwards
September 18, 20169 yr My friends bike (175cc with the shorter extension (35mm I think) and 5mm lower axle slot) has the standard frame loop and feels lovely to ride, slightly more stable than standard. I'll see if I can find a photo of his bike Mine is 205cc and 45mm extension and is also very nice (more stable than standard) Photo of friends bike attached. Note his bike has non-standard fork tubes (much longer than standard) Edited September 18, 20169 yr by feetupfun
September 19, 20169 yr is it possible to still get new stanchions for the ty....mine are rooted and getting them hard chromed and ground over here in N.Z. is foooookin hard work and expensive.......unless someone can inform me different.
September 19, 20169 yr I think there are new aftermarket tubes available from the US and the price is pretty much the same as getting the originals redone. Those tubes on Greg's bike came from a different bike that had 30mm tubes. From memory they might be from a CR80. I have seen other TY175s with shortened tubes from 80cc MX bikes. Early DT100,125 and 175 and early Yamaha AG bikes had 30mm tubes too, but because they are just as old as TY175 tubes it is rare to find good ones. Last time I had a set done (in Brisbane) they were $150 per tube plus postage, but it has probably gone up since then
September 19, 20169 yr is it possible to still get new stanchions for the ty....mine are rooted and getting them hard chromed and ground over here in N.Z. is foooookin hard work and expensive.......unless someone can inform me different. Bashplate try Dynasurf Sandbach UK, they do a really good job. I imagine because you are in NZ you would not be charged our vat which is 20% Edited September 19, 20169 yr by trialsrfun
