Keihin carb needle ??
Can anyone tell me if the needle on the Keihin carb just sits in the slide via gravity?
What I mean by that is, does it just sit there and not held down under tension??
There a white plastic part holding needle down tensioned by the big coil.
So this white plastic part should sit on top of needle held down under tension by the spring on the slide ye ??
