dmc2028372 Posted July 13, 2017 Share Posted July 13, 2017 Hi. I'd like to find my boy a medium wheel 80 but it seems all you get second hand are big wheel versions. My question is can you retro fit a set of medium wheels onto a big wheel bike? Quote Link to comment Share on other sites More sharing options...
collyolly Posted July 13, 2017 Share Posted July 13, 2017 I imagine with a bit of work any modification like that is possible it's just a question of is it worth it. Smaller wheels will only lower the seat height by an inch so perhaps the smaller bike has different forks and rear shock ? Also how much is a set of special wheels and tires going to cost, how about just lowering the standard bike after all I assume the smaller class don't go over large logs or steps so perhaps the ground clearance could be given up to get the lower seat , just a thought. After all this must have been looked into before. Quote Link to comment Share on other sites More sharing options...
dmc2028372 Posted July 13, 2017 Author Share Posted July 13, 2017 Some good points. I just can't find a second hand medium wheel 80 for love nor money. I'm not sure my boy is that keen that it warrants a new one. Is there anything else on the market that will plug the gap between and oset 20 and and a beta 80? Quote Link to comment Share on other sites More sharing options...
johnsandywhite Posted July 13, 2017 Share Posted July 13, 2017 The Oset 24.0R is the same size as the Beta 80 mid wheel and has about the same power which can be adjusted in 3 different ways. 1. Speed 2. Power 3. Throttle response. The only difference to riding one as against the Beta is the clutch lever on the Beta is a rear brake on the Oset, so no rear foot brake. Quote Link to comment Share on other sites More sharing options...
