July 27, 20179 yr Hi i got 17 evo 4T factory and every time my bike die on little hill it always spits fuel from carb on ground.Also it's very hard to start when hot afterwards. should I adjust the float bowl or do the billy mod? jetting is 130 main and 25 pilot fuel screw out 1.5 thanks Edited July 27, 20179 yr by gu9cci
July 27, 20179 yr The mod is because the carb on the two stroke has a bit of a downdraught and is sensitive to float level. That on your bike is more or less horizontal so should not be a problem (though any carb has to be correctly set). There is a hot start mechanism but I am not familiar with it - the manual can be downloaded.
July 28, 20179 yr All ways use the red hot start button when the bike is warm. Even then if i kick it twice and it does not fire, i will have to hold the throttle wide open as well as the red button on as i kick it.
July 30, 20179 yr Author Ok i adjusted the float in carb and bike is running perfect. starts first kick hot without hot start.
