chatlie44 Posted September 5, 2017 Share Posted September 5, 2017 I have purchased the trp stiffer spring for my Montesa showa shock, I looked in my manual and it doesn't tell you how to remove the spring, do you just loosen the preload rings and remove the retaining cup like a normal shock or is it different. Thought I would ask on here before I use the trial and error approach. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted September 6, 2017 Share Posted September 6, 2017 Yep 1 Quote Link to comment Share on other sites More sharing options...
jmutiger Posted September 7, 2017 Share Posted September 7, 2017 It's a fight to get the clip off to remove the retainer. Getting it back together isn't nearly as hard. I did it but wasn't sure I'd be able to without some kind of spring compression device. Quote Link to comment Share on other sites More sharing options...
