September 14, 20179 yr My new bike is extremely hard to start and very unpredictable. I never give it any throttle and It takes forever to get it started, usually after about 10 kicks I hold the throttle open and kick it a couple times to reset it and after doing that a couple times it will start. Then this morning I go out and first kick it starts. Then after it's been running whenever I turn it off and then try to restart it I have to go through the same procedure, kick it a bunch then hold throttle open. it usualy takes anywhere from 10 to 20 kicks. I read somewhere that pushing it instead of hard kicking it seems to help so I've tried that as well. Any tips or suggestions are welcome and thanks in advance!
September 14, 20179 yr You need to raise your Idle. It should be set at 1800 RPM. See your manual for the location. Turning the idle screw out will raise the idle. I normally do a reset after 3-4 kicks. 10-20 is too many. Or you need a new spark plug. Make sure you have a little play in the throttle and that the air filter does not have too much oil on it.
September 14, 20179 yr Author I turned the throttle screw out about 1/4 turn, this seems to have really helped but I have no idea if its at 1800. I can start it now with the 1 or 2 kicks!
September 15, 20179 yr one option on the 1800 would be an hour meter with an RPM function? If not you might be able to find a shop that would check it for you? and yes that 1800 really helps on starting the bike!
September 15, 20179 yr I had exactly the same problem with my Montesa. New iridium plug sorted issue. Never fails to amaze me, how easy my bike starts even after weeks sat doing nothing. It is definitely a push more than Gas Gas style kick.
September 15, 20179 yr Yeah, a two stroke kick is no use, took me a while to get used to that. A lot of hour metres measure RPM.
September 16, 20179 yr Author On 9/15/2017 at 1:35 AM, cragvale said: I had exactly the same problem with my Montesa. New iridium plug sorted issue. Never fails to amaze me, how easy my bike starts even after weeks sat doing nothing. It is definitely a push more than Gas Gas style kick. I might try swapping plugs, what plug are you using?
September 27, 20178 yr One thing you can do is get an hour meter that shows RPM. The one ride engineering makes for KTM four strokes works, although you need to make sure you have some double sided tape (or if you ordered from them, make sure they send you some. You can install it without taking anything apart. I got rid of the elaborate tank vent system and placed mine on the frame on the kick starter side up by the top of the triple clamp. Works connection also makes one....... Edited October 26, 20178 yr by motomickey
