September 25, 20179 yr Hi Chaps, As I stated earlier we have just got hold of a gas gas 125 txt 2000. Does anyone know where they have hid the CDI unit. Have found the coil ok, but the cdi unit is well hidden. All help appreciated. Nubsey
September 25, 20179 yr From memory like a lot of bikes it's a 1 piece coil/CDI unit. Can you put up a photo of the coil to confirm Edited September 25, 20179 yr by tony27
September 25, 20179 yr Author Thanks for the replys chaps, will be checking them out when I get the chance. I suspect that all is ok with it and it is a coil or grounding issue as there is quite a lot of ommph getting to the plug as you get quite a belt from it, Just not enough to give a spark I guess. All the best to all Nubsey
