nubsey Posted September 25, 2017 Share Posted September 25, 2017 Hi Chaps, As I stated earlier we have just got hold of a gas gas 125 txt 2000. Does anyone know where they have hid the CDI unit. Have found the coil ok, but the cdi unit is well hidden. All help appreciated. Nubsey Quote Link to comment Share on other sites More sharing options...
tony27 Posted September 25, 2017 Share Posted September 25, 2017 (edited) From memory like a lot of bikes it's a 1 piece coil/CDI unit. Can you put up a photo of the coil to confirm Edited September 25, 2017 by tony27 Quote Link to comment Share on other sites More sharing options...
althespanner Posted September 25, 2017 Share Posted September 25, 2017 bolted under top gusset of frame from bottom Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 25, 2017 Share Posted September 25, 2017 All the way up to the steering stem. it is packed tight. Quote Link to comment Share on other sites More sharing options...
nubsey Posted September 25, 2017 Author Share Posted September 25, 2017 Thanks for the replys chaps, will be checking them out when I get the chance. I suspect that all is ok with it and it is a coil or grounding issue as there is quite a lot of ommph getting to the plug as you get quite a belt from it, Just not enough to give a spark I guess. All the best to all Nubsey Quote Link to comment Share on other sites More sharing options...
