Swingarm Help !
B) Does anyone know where I can get some swingarm bearings and the related peices??? or does anyone make a bushing to replace the needle brg.?
1983 240 pro ;)
thanks for any info.
:PB)
glenn
If you reply with your e-mail address I will send you a pdf of the Parts catalog page C3.
There are quite a few pieces as you have probably discovered.
From the middle of the swingarm you have small seal. nylon bush. needle brg, small seal, large seal and cap.
Will see if I can find a chart of the sizes in the meantime.
Yes please, i certainly could do with that kind of Info
pls mail to LHarris(atsign)amidoduco.com
