Colm Posted December 31, 2017 Share Posted December 31, 2017 Hi all . I’m new here and this is my first post , I ride a 2014 Sherco 300 , mainly fun riding in woods and I purchased an hebo auxiliary fuel tank , before I tear into the install , has anyone here done this mod ! Bearing in mind my fuel tank is in the back with no vent from the filler cap . Thanks Quote Link to comment Share on other sites More sharing options...
spen Posted January 1, 2018 Share Posted January 1, 2018 I carry an aluminium vodka bottle and top up as necessary.... it contains petrol not vodka.... Quote Link to comment Share on other sites More sharing options...
copemech Posted January 1, 2018 Share Posted January 1, 2018 not recommended on that tank system that I am aware of. plastic or ali pop bottles in a backpack work well. Quote Link to comment Share on other sites More sharing options...
Colm Posted January 1, 2018 Author Share Posted January 1, 2018 Thanks guys Quote Link to comment Share on other sites More sharing options...
baldilocks Posted January 1, 2018 Share Posted January 1, 2018 It does work with that tank you just need a very long pipe to go from the breather on your rear tank to the auxiliary tank. Lots of people used them at the SSDT. You'll need to remove the one way breather from under the mudguard. Quote Link to comment Share on other sites More sharing options...
Colm Posted January 1, 2018 Author Share Posted January 1, 2018 That’s good to hear thanks , ?? Quote Link to comment Share on other sites More sharing options...
pauls320 Posted January 1, 2018 Share Posted January 1, 2018 Not trying to be insulting to any owners of '10-'15 Sherco owners....but this fuel hose labyrinth model is famous for issues already..adding yet more hose etc would just compound potential...problems....Maybe use the Aux tank as the main, gravity feeding the carb and have the original tank pump contents to Aux, with overflow line back to said original...eliminating restrictor valves, ''tee's'' and other configuration issues of original set ups 2 Quote Link to comment Share on other sites More sharing options...
Colm Posted January 6, 2018 Author Share Posted January 6, 2018 On 01/01/2018 at 3:41 PM, baldilocks said: It does work with that tank you just need a very long pipe to go from the breather on your rear tank to the auxiliary tank. Lots of people used them at the SSDT. You'll need to remove the one way breather from under the mudguard. Just done this mod in about 25 minuets , working a treat ?? Quote Link to comment Share on other sites More sharing options...
