M49 advice please!
On 28/02/2018 at 8:21 AM, feetupfun said:
Some alloy steels have a low coefficient of friction so be careful. Mild steel or cast iron are the go for brake drums
I always found it interesting/amusing that other manufacturers used chrome on cylinder bores to reduce friction (as well as increase  bore life) .  Bultaco used it on brake drums...........
  • Replies 39
  • Views 10.3k
Most Popular Posts
  • Well, just finished machining the drum, it is indeed a cast - in liner. I've taken it out to the nominal diameter of the aluminium, I'm guessing 144 ish mm. Just got to sleeve the bearing diameter whi
  • But, a used Yamaha TY hub could be just as worn, there's no guarantee they work any better. I've ridden Yams with dire brakes as well as good. My Sherpas have decent brakes using modern shoe linings m
  • Kind words! I remember reading about a Japanese tuner in the 70s who would skim drums true, lace up the wheels then heat them up before a final skim. In my case, it's just laziness....??
The brakes on my M138 Alpina (with chrome plated drums) are amazing
I suppose I would have to concede that an almost frictionless chrome surface would not be any worse than the cast iron lined brakes on Bultacos I rode as a teenager☺
Interesting bit of machining Blueflag, how tight a fit are you going for on your liner, given the different coefficients of expansion of steel  / alloy?
And how are you going to stop the liner from turning, just by the interference fit alone?  Or with the aid of a bit of Loctite or similar?
Cheers,
Craig
It's got an interference fit, chill the liner and warm the hub to get it in. I can't see it getting particularly warm the way I ride! I put a little bit of loctite on the face just as belt and braces. I'm pretty happy with the way it's gone. I need to sort out some shoes, a brake rod and a new lever. Keeps me out of mischief...
I know the finish has chatter by the way...?
Edited by blueflag
Missing information
Great stuff Blueflag, I love this kind of work to keep the old ones going
Thanks Craig, I know what you mean mate, feel like an active historian! So much I need to learn though!
Nice work. I'm also impressed that you did it all with the wheel assembled
