Ty 175 dt gearbox
T6AVN
Anyone tried using a dt 125/175a gearbox on a ty from this I mean using the left crankcase of a ty and  right crankcase of a dt so that a ty flywheel can be used I have the parts so was thinking of trying it. The only thing I can see as an issue is the selector fork supports need to be turned down a little to fit in the ty case and I would have to use each half of a crank
I'm not sure if any I remember speaking to someone a while ago who said it had been done before as the gear ratios were better. I have the parts so was thinking of trying it just wondered if anyone else had done it
