December 20, 200520 yr Just got a Yamaha type kill button to fit on my 200 Fantic. It has the original coil on it. Whats the recommended way to feed into the coil and which wire do you feed into?
December 24, 200520 yr On my 240's wire diagram , the kill switch goes to the C terminal on the coil. Should be the rosso (red) lead that comes from the stator plate,hook it to that terminal thru the switch , then to ground. All the kill switch does is short ign. voltage to ground. cheers Glenn
