Varlo Posted June 2, 2018 Share Posted June 2, 2018 Hi, has anyone any experience with cartridge emulators fork valves? Or yss pd valve. thinking of trying them in my ty 250 twinshock. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 2, 2018 Share Posted June 2, 2018 Yes I run Racetech gold valves in TY250 twinshock forks on a Godden Majesty. They work very well, once set up properly. The instructions say that you might need stiffer springs. Unless you are very light or use the forks on a lighter bike, you probably will need stiffer springs. 1 Quote Link to comment Share on other sites More sharing options...
Varlo Posted June 2, 2018 Author Share Posted June 2, 2018 Do you know if there's similar to majical dampers ? Quote Link to comment Share on other sites More sharing options...
guy53 Posted June 2, 2018 Share Posted June 2, 2018 I installed a set of Gold Valve a few years back and here's what I think: They are not the ultimate thing, but for me, they made a difference on rough ground at low speed the way I set them up. You get use to them quickly and don't fell any difference until you test standard and modified forks back to back. My TY have longer and inclined shock so the steering is a little steeper than original. Are they worth the money, before a long ride no after yes. Guy 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 3, 2018 Share Posted June 3, 2018 19 hours ago, Varlo said: Do you know if there's similar to majical dampers ? There are magical shocks and magical fork springs. I haven't heard of magical cartridge emulators Quote Link to comment Share on other sites More sharing options...
