290 shock identification
misterroy
Hi, I thing I have a 2006 290 Sherco, the bottom bearing is finished, I ordered one and the new bearing is 26mm OD, the old bearing was 22mm OD. Is this not the original shock? The are no markings on the shock.
Sherco used Olle units, looks like the one that was in my 2005. older units used 22mm, newer 26mm.... Be best to check with splatshop guys to be sure or other knowledge source . Best of luck
