guy53 Posted October 8, 2018 Share Posted October 8, 2018 I just bought a 2015 ST 250 in very good condition, I had a 03 rev 250, I find the ST light and agile but a little '' nervous ''. I mostly ride the bike in the mountain, don't really enjoy competition and I am past my prime !!! I also find the gearing a little tall so here's what I think : I already change for a slow throttle, I will replace the 42t for a 44t rear sprocket to cure the low speed problem and I ordered a flywheel puller to put less advance in the timing. Also the mapping switch is on '' S '', does that really work or is it just a gadget ? Advise very welcome. Guy Quote Link to comment Share on other sites More sharing options...
section swept Posted October 8, 2018 Share Posted October 8, 2018 What size gearbox sprocket is fitted, you will have a better effect on gearing at the front (g/box) if the sprocket is not already as small as can effectively be used. Quote Link to comment Share on other sites More sharing options...
guy53 Posted October 8, 2018 Author Share Posted October 8, 2018 It is fitted with a 10t, I did not want to go too low. Guy Quote Link to comment Share on other sites More sharing options...
cascao Posted October 9, 2018 Share Posted October 9, 2018 If nothing else work....Try closing reed valve gap a bit... Quote Link to comment Share on other sites More sharing options...
copemech Posted October 9, 2018 Share Posted October 9, 2018 44 is a decent trade, as the 9 on front is just too low! See how you do before messing with timing. Does it have a dellorto carb? Quote Link to comment Share on other sites More sharing options...
guy53 Posted October 9, 2018 Author Share Posted October 9, 2018 Yes it does Guy Quote Link to comment Share on other sites More sharing options...
copemech Posted October 9, 2018 Share Posted October 9, 2018 6 hours ago, guy53 said: Yes it does Guy That is good. Less powerfully than the Keihin. Quote Link to comment Share on other sites More sharing options...
brianrch Posted October 11, 2018 Share Posted October 11, 2018 I have a 2015 ST 250 and though I agree that the gearing may be a little tall, I am using the stock gearing. I tried a 44 rear and went back to stock. I find that stock gets good traction, climbs well and offers good control. Quote Link to comment Share on other sites More sharing options...
guy53 Posted October 11, 2018 Author Share Posted October 11, 2018 Brianrch, you are right, but I would like a little slower 1st gear around trees. Do you find any difference in the 2 setting of the mapping switch ? Guy Quote Link to comment Share on other sites More sharing options...
brianrch Posted October 13, 2018 Share Posted October 13, 2018 Not really, i also just leave it on S Quote Link to comment Share on other sites More sharing options...
