Anybody Got Any Petrol Tanks Lying Around?
i'm not haveing much luck with a beamish tank, so if anyone has any other make tanks going let me know. i'll make some mesurements later to get an idea of what will fit.
thanks
Ben :D
if its a beamish tank your after sammy miller used to do a pattern one for them sure he still does
TY175 tank should fit frames for the piston ported bikes(mk1/2),but you will need to play with the size of the rubber frame mounts by the headstock from memory they need to be thinner to fit the grooves on the tank...cable tie the seat end with some foam if you can't find a better method
cheers
Ben
Have you tried talking to Roger Painter (secretary of the Wilts & Dorset Trials Club)....I dont have his number to hand but they usually have a trial listed in the back of T&MX News. Roger has ridden Beamishes for years and often does shows and autojumbles selling Beamish bits, if anyone has a tank....he will.
Cheers
Martin
got hold of roger painter, he has a small amount of bits left for silver engine models. no petrol tanks :(
thanks for the pic twinshockdude, i found a ty tank this morning, for
  • 1 month later...
