bigfoot Posted January 27, 2004 Report Share Posted January 27, 2004 I was having problems starting me 2001 280 recently and so serviced the carb. It was a little dirtly and had a little water in the bowl but otherwise was OK. The bike now starts but runs badly. It pinking, hunting and not ticking over very well. I think its running too rich/lean and have tried adjusting to no avail. How many turns out should the mixture be set of normal UK riding? Link to comment Share on other sites More sharing options...
jtt Posted January 27, 2004 Report Share Posted January 27, 2004 Did you blow out all the orifaces?? Sounds like you unlodged something that is now jammed in a jet, most likely the pilot. I'd take it back off and carefully flush and blow out all the jets and the orifaces in the carb. Fuel screw setting will vary place to place and even day to day. Suggest you start at about 3.5 turns out and work from there. Link to comment Share on other sites More sharing options...
ronm Posted January 27, 2004 Report Share Posted January 27, 2004 Hi Big, It sounds like either you still have a clogged jet or you have an airleak. Be sure you carefully check the intake boot. My TXT intake boot started cracking after just a couple of years. Any air leak whatsoever will cause the symptoms you described. Link to comment Share on other sites More sharing options...
bigfoot Posted January 27, 2004 Author Report Share Posted January 27, 2004 It is a little cracked but I didn't think it would draw air that easily. I did blow the whole thing out and I'm sure it was a little blocked but not any more. Link to comment Share on other sites More sharing options...
charliechitlins Posted January 27, 2004 Report Share Posted January 27, 2004 You don't want it to draw air AT ALL. It's easy to check by squirting water on it while it's running. You can also use a propane torch. Don't light it. Link to comment Share on other sites More sharing options...
bigfoot Posted January 27, 2004 Author Report Share Posted January 27, 2004 Great tip that Charlie I'd never thought of using a little gas to check for intake leaks. I'll try it. Link to comment Share on other sites More sharing options...
charliechitlins Posted January 28, 2004 Report Share Posted January 28, 2004 I think I replaced my first Bultaco compliance fitting around 1975. Spanish rubber parts were funky then, and they're funky now. I don't know why it's so, but it is. Heck...when the tires on my Sherco began to slowly lose air, it turned out to be the valve cores. That little bit of rubber in there had stopped sealing. It's a good idea to change any intake rubber at the first sign of cracking. I hit them with a little silicone periodically. It makes me feel better. Link to comment Share on other sites More sharing options...
petersdraggin Posted January 28, 2004 Report Share Posted January 28, 2004 (edited) i had to replace the intake boot on my kids txt70 as well.i also had a carb problem a few years ago.i took it off and cleaned it out but still had them same problems as stated above.well to make a loong story short i traced it back to senderos gas i was out of gas in my can so i barrowed some from good ole sendero.it took a while but i traced it back to the 2 stroke oil we use.sendero uses the natural stuff and i use synthetic.so i drained the tank and put fresh new gas in and the problem was solved.it may have been something else but who knows? Edited January 28, 2004 by petersdraggin Link to comment Share on other sites More sharing options...
gii Posted February 13, 2004 Report Share Posted February 13, 2004 Be careful using the unlit propane torch to find a leak in the inlet manifold. It works and it is quick and efficient. It is also a good way of finding leaks in the HT circuit. It works well, but be careful Link to comment Share on other sites More sharing options...
beta boy Posted February 15, 2004 Report Share Posted February 15, 2004 when i got my beta you could fit your little finger in one of the holes on the intake mani fold i soon had that replaced the person who ahd it before me was riding with it like that Link to comment Share on other sites More sharing options...
jtt Posted February 15, 2004 Report Share Posted February 15, 2004 when i got my beta you could fit your little finger in one of the holes on the intake mani fold i soon had that replaced the person who ahd it before me was riding with it like that ...and YOU BOUGHT IT??? Link to comment Share on other sites More sharing options...
beta boy Posted February 15, 2004 Report Share Posted February 15, 2004 yeah because it was cheap and cause i knew the person that had it Link to comment Share on other sites More sharing options...
bigfoot Posted February 17, 2004 Author Report Share Posted February 17, 2004 How do you know the size of my little finger? I've sort of resolved the fault but not totally. I recleaned the carb and it was still not good but after a couple of thrash runs up some big hills it all of a sudden cleared. The problem now is that it sometimes just dies on tick over and is very difficult to restart. Link to comment Share on other sites More sharing options...
monty-python Posted February 17, 2004 Report Share Posted February 17, 2004 STICK IT IN SCOT-ADS, AND BUY A NEW ONE, YOU KNOW YOU WANT TO!! Link to comment Share on other sites More sharing options...
bigfoot Posted February 18, 2004 Author Report Share Posted February 18, 2004 I do but will have to leave this section and go to the Beta one. It's the Rev 3 for me. Only a matter of time now. Do you know of anyone inporting Beta's? Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
