Gah. New ignition, new problems.. TXT300...
  • Replies 47
  • Views 14k
Most Popular Posts
  • In relation to chat about main bearings above - There is a gallery in the transmission that basically catches oil "thrown" up by the gears rotating. it feeds this transmission oil into a gallery behin
  • scarboroughbeta
    scarboroughbeta
    Good evening  I've recently had the same problem with my 2007 beta rev 3 . It sounded exactly the same and smoked the same . I checked threw all the electrics . On the cdi i found a bared wire wh
  • I give up.
6 minutes ago, thall1 said:
Fixed with a new woodruff key?
No. Long story, but borrowed an ignition off a friend and that worked, then found that the polarity of the pickup was reversed and hidden behind the original heatshrink sleeve.
Changed the polarity and its running fine now!
The strange thing is, I tried another stator and pickup and it was the same..
Always the smallest things eh
