martinsyderob Posted July 8, 2019 Share Posted July 8, 2019 Hi. Just got a 2016 evo factory, my old 2010 has an ohlins rear shock. Will this swap over to the 2016? I thought I'd ask rather than get both in bits and find out it's not compatible. Thanks rob Quote Link to comment Share on other sites More sharing options...
dan williams Posted July 8, 2019 Share Posted July 8, 2019 Probably best to ask Ohlins. Quote Link to comment Share on other sites More sharing options...
5again Posted July 9, 2019 Share Posted July 9, 2019 My 15 Factory worked great with an Ohlins off a standard Evo, I think the 17 Factory was the switch to R16V shock. I think the 16 will be fine. Quote Link to comment Share on other sites More sharing options...
martinsyderob Posted July 10, 2019 Author Share Posted July 10, 2019 15 hours ago, 5again said: My 15 Factory worked great with an Ohlins off a standard Evo, I think the 17 Factory was the switch to R16V shock. I think the 16 will be fine. Was the std evo you got the shock off a 2015 bike? Quote Link to comment Share on other sites More sharing options...
5again Posted July 10, 2019 Share Posted July 10, 2019 Yep, I used the same Ohlins unit on a std 12, std 15 then the Factory 15. Quote Link to comment Share on other sites More sharing options...
carlos Posted August 2, 2019 Share Posted August 2, 2019 I believe the Factory 13 and Factory 17 had slightly longer shocks. Different aluminum cam as well. The upper and lower frame mounts are all the same on all EVO models. Quote Link to comment Share on other sites More sharing options...
