jmutiger Posted August 24, 2019 Share Posted August 24, 2019 If you are like me, you find the weak links on bikes pretty quick. To me our 4rt footpeg pin set up leaves some room for improvement. If your in the USA or Canada and want to setup your bike like this contact me and I'll help you out. These are aircraft grade AN bolts and there is no threads where there shouldn't be, like under the hanger or footpeg. See pics for what I'm talking about. This is a 300rr with CSP hangers but the bolts are available in any size pretty much. Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 24, 2019 Share Posted August 24, 2019 The weak link is the frame itself. Keep on eye on it. Putting on stronger mounts, bolts and peg compounds this problem. 1 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted August 25, 2019 Share Posted August 25, 2019 (edited) I am not sure I would go with different hangers on a 4RT/300RR, though upgrade to the pegs and bolts are fine in my mind. As Lineaway indicated the frame can be broken if you put on stronger hangers and take a big hit. I would rather replace a set of bent hangers then have to weld a frame. Hope that helps. Edited August 25, 2019 by jonnyc21 1 Quote Link to comment Share on other sites More sharing options...
