carlos Posted May 17, 2020 Share Posted May 17, 2020 I measured a 7.7mm gap, not much room with a 6mm wide seal but water will always find away. Will give it a try when the new stock seal wears out. Quote Link to comment Share on other sites More sharing options...
Dean K Posted September 17, 2020 Author Share Posted September 17, 2020 So the new OEM seals and shaft started to weep after about 50 hours after I replaced them. It wasn't leaking that bad so I kept riding but keeping an eye on the coolant level (just a slight drip so maybe a few ounces lost) now after 131 hours I took it apart to see how bad the shaft was and it was worse than the first one that I replaced. I put in a new shaft, and left the old seals in, started the engine and warmed it up and they are not leaking. Going the see if they hold up with just replacing the shaft. I believe the shaft needs to be made from a better material or I need to try those non OEM seals that are softer on the contact area. Anyone know if I could have the shafts built up and reground or sleeved somehow? Replacing the shaft at 50hrs. is not cool. Quote Link to comment Share on other sites More sharing options...
Dean K Posted September 17, 2020 Author Share Posted September 17, 2020 Does anyone have any ideas or fixes I might want to check out? Quote Link to comment Share on other sites More sharing options...
trialsrydr Posted March 19, 2022 Share Posted March 19, 2022 Hello Everyone, This thread saved me. I was ready to tear the Head off my bike for a leaking Head Gasket. Thanks for posting. I am waiting on parts. So, I have not removed anything yet. Does anyone have anything new for the good of the order? Can anyone provide any more details on how to make the tool for removal of the pump shaft, photos, different angles, other solutions, anything? Beta should provide a little something for this when you buy the bike. Any additional information would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
trialsrydr Posted March 19, 2022 Share Posted March 19, 2022 Oh! One more thing. Do I have to remove the pump shaft in order to replace the seal(s)? My bike is a 2017 with 10 hours on it. I think the seal(s) just dried out. The shaft is probably fine. Quote Link to comment Share on other sites More sharing options...
trialsrydr Posted April 1, 2022 Share Posted April 1, 2022 Okay, I set the TDC bolt on the bottom of the case (6mm Allen Head) and wrapped the water pump shaft with a small piece of nylon window screen and small piece of masking tape. I tightened up a medium sized Crescent wrench on it and gave it a couple jolts. It loosened up no problem. I layed the bike over on its left side, resting on the handlebar end (not good. I know. But, I didn’t want that pump gear going anywhere down the cam chain shaft) I slowly backed out the water pump shaft, standard rotation, until I felt it click at the end of the threads. I slowly pulled it out. The outer seal came out on the shaft. It was probably spinning around in the housing. I ordered the factory seal. But, it appears to be about 1mm too big for the housing at the outer diameter. I can’t even imagine it fitting in without crushing it. It is a super hard rubber so I am stumped about how to put it in without destroying it. If anyone has any wisdom it would be greatly appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
TRR Posted February 7, 2024 Share Posted February 7, 2024 Is it necessary to back off the cam chain tension to remove water pump shaft with bike laying on its side? Quote Link to comment Share on other sites More sharing options...
