new rider help
hi i have just returned to trials scorpa 280 im 57 been off the trials since the early 90s and did my first trial today and loved it getting better every section but there is one thing that i cant get right i can turn tight on off camber ok but turn tight on the flat and the front wants to push away from me tried leaning the bike over a bit more helped but was still bad running 5psi in the tyre was tacky conditions
Are you using the clutch ? Maybe drag the back brake a little. Handlebars a little further forward to put more weight onto front tyre.
Many thanks will try that i am using the clutch will move the bars and have a try
Wheres your forks on the triple clamps? Maybe drop the clamps a little
What condition is your front tyre ?  What make is it, 5psi in a decent quality tyre should be about right.
x11 or dunlop looks good but will change it forks are fully up top will go for tyre and bars forward and give it a try so i know whats doung what i do yus the clutch but it is a bit snappy will have a play with that many thanks for the pointers
