Undersize fork seals
I recently changed the seals on txt pro but the od of the seals supplied are undersize. They seemed to fit ok
The od should have been 52.2mm but the ones supplied are 52.0mm, they don’t seem to be leaking but I’ve not done a trial yet!
Anyone else had this issue, I don’t fancy wasting the oil to change them
Don't think I would have fitted them .Id change them for the correct ones in case they start leaking at an event and contaminate the brake pads as well.Id get the new seals from a different source too
I wouldn't have fitted them normally, I just presumed they were correct.
It was only after I looked at the old ones I noticed the size difference ?
Edited by suzuki250
Annoying,some of the crap stuff that's out there.Means doing the job twice through no fault of your own
22 hours ago, twinshockdude said:
0.2mm = 0.008"  dont worry about it !
Very True
the only way to find out is to do a trial :thumbup:
