January 30, 20206 yr does the later 260 4RT have maintenance free valve clearance adjustment such as hydraulic tappets or do they need shims and if so how often , thanks
January 30, 20206 yr They don't tend to alter much unless you rev the nuts off it frequently,then they close up which makes it harder to start when hot as the valves don't seal completely
