sparkieb Posted February 28, 2020 Share Posted February 28, 2020 Im at the stage where its time to refit the exhaust, engine is in and its a rolling chassis. Do i have to start removing parts again ? as im getting nowhere fast and catching all the new paint. Does the cylinder head need to come back off ? Does the rear wheel need to come out ? Im sure when i dismantled the 348 it came out without doing so but was difficult. Hope someone out there has a solution. Cheers Mark Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted February 28, 2020 Share Posted February 28, 2020 (edited) It is a fiddle and I haven't done it for forty years but I seem to recollect that you start with the tail pipe facing towards the front then thread the curved pipe through between the downtubes from back to front then wiggle it from there. My memory may be false of course. Edited February 28, 2020 by 2stroke4stroke Quote Link to comment Share on other sites More sharing options...
sparkieb Posted February 28, 2020 Author Share Posted February 28, 2020 Its in ? after removing air box then feeding thru from front with a bit of twisting. BUT ? the rear mudguard was offset so i spent ages re-aligning so i looked perfect, but guess what ? the bloody silencer hits it now, so they must all be built offset. Well mines bloody well not , so im trimming the underside edge of the mudguard until it bolts up. If there was a montesa designer about id be tempted to give him a tap in the nuts ? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted February 28, 2020 Share Posted February 28, 2020 I think there were a few with melted mudguard edges? 2 Quote Link to comment Share on other sites More sharing options...
nh014 Posted February 29, 2020 Share Posted February 29, 2020 It is considerably easier with the rear wheel, rear fender, and air box removed. 1 Quote Link to comment Share on other sites More sharing options...
barnesy Posted February 29, 2020 Share Posted February 29, 2020 I had the very same problem a few months ago when i repacked my exhaust, airbox off, rear mudguard off still couldn't refit exhaust, Take the coil off and hey presto it fits. The extra wiggle room with the coil off does the trick.. 1 Quote Link to comment Share on other sites More sharing options...
