austin6728 Posted March 9, 2020 Share Posted March 9, 2020 just replaced the plastic idle carb screw with a DAB aftermarket one and i cant get the bike to idle. Ive had it screwed all the way in but makes no difference anyone had the same problem and have a solution?? not tried messing with the air screw yet as its a bugger to get to Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 9, 2020 Share Posted March 9, 2020 Have you compared the old and new side by side ? Quote Link to comment Share on other sites More sharing options...
pauls320 Posted March 10, 2020 Share Posted March 10, 2020 Does the replacement have sufficient thread length? The oem blue thread compound often gums up the internal threads in the carb body, might want to chase hole with the correct tap...carefully to not allow debris into carb/engine. Quote Link to comment Share on other sites More sharing options...
austin6728 Posted March 10, 2020 Author Share Posted March 10, 2020 Just compared the idle screws and and they have different thread lengths the aftermarket DAB on being shorter therefore with the spring on it wont screw far enough in to the carb so the option is to shorten the spring or go back to the original screw Thanks for the input Quote Link to comment Share on other sites More sharing options...
austin6728 Posted March 10, 2020 Author Share Posted March 10, 2020 Just checked my order on Ebay I BOUGHT THE WRONG IDLE SCREW ? returned today 1 Quote Link to comment Share on other sites More sharing options...
austin6728 Posted March 13, 2020 Author Share Posted March 13, 2020 On 3/10/2020 at 10:59 AM, austin6728 said: Just checked my order on Ebay I BOUGHT THE WRONG IDLE SCREW ? returned today yeh fussy ? mistake need to be more careful with the online shopping at 2am ?? Quote Link to comment Share on other sites More sharing options...
