Villiers 9e clutch
walkertrials
Should there be a ball bearing behind the clutch pushrod  & when arm is pulled in how far should pushrod protrude from end of shaft see photo. Not ready for re-build but making a shopping list of parts ready for Villiers Services order, thanks.
14 hours ago, teamferret said:
If you are going for their 'yamaha' conversion the pushrod will need shortening (and the mainshaft)
No keeping standard just fitting modern plates, it worked when last used I just expected a ball after I took the pushrod out. The pushrod protrudes out the shaft by 1mm (0.040 thou)
