May 26, 20206 yr Im just doing a refurbishment of a gas gas ec 250 2005,and found that the lower shock mount is cracked near the shock station so un repairable, I can't find a suitable spare, so does anyone know of and other manufacturers shocks that fit this bike cheers. The shock is 430mm eye to eye.
June 2, 20206 yr Author No it's an odd length, with the piggy back at a slight right angle to the upper mount so most wount fit, after some research online some older tm 250 shocks are the same, but you don't see many up for sale.
June 4, 20206 yr I guess you'll need to find someone breaking one then! It's worth searching in Europe, there's loads of them around here
