September 12, 20206 yr Anyone found a more robust tyre beader Dunlop made them years ago out of rubber which were a lot more robust. Just split one tonight rushing to get it done !
September 12, 20206 yr I use a bicycle tube that is even less robust than the shop bought things. Got 5 years so far out of this one. My last one even had a few patches on it ? Edited September 12, 20206 yr by faussy
September 14, 20206 yr I use this super thick tube. https://www.amazon.com/Nuetech-Tubliss-Inner-Tube-Rear/dp/B0065725RI You can get them for free from enduro users who throw away damaged ones.
September 14, 20206 yr 3 hours ago, baldilocks said: 20 inch tube ? Yes. Best at a lowish psi (too low and it won't seal, too high and it pops out too early) with a little soap. Don't come at me if you try it and either get frustrated at it not working or end up ripping the tube. There is more of a knack to it than using a beader. When i started doing it in the 90s i didn't realise beaders existed and put up with the slight inconvenience. Now im virtually as quick as someone else using a beader and too tight to splash out on something that will only save me a few seconds ? Edited September 14, 20206 yr by faussy
September 15, 20206 yr Did you lube the beader up? I cover the beader in tyre soap and put extra in the well in which I put the beader in. Makes it slide out really nicely.
