2020 txt pro clutch pack specs
Can anyone tell me what the clutch finger height spec is for the 2019 and newer gg pro require. I found a spec for pack thickness, which at 9.9-10.02 mm is slightly thicker than previous. My 20 clutch has become harder to pull and would like to restore the easy pull it did have.
Thanks in advance!
Absolutely loving the mighty GG
Previous finger height was about 17mm, but you may also find that there is a buildup of filings and other detritus behind the pressure plate and spring which is often a cause of a stiff clutch.
Spencer
