Robboshome Posted February 3, 2021 Share Posted February 3, 2021 Does anyone have advice on any inlet manifolds or adapters to allow throttle cable to enter without trying to bend round crossbar, must be some method out there ? Quote Link to comment Share on other sites More sharing options...
naichuff Posted February 3, 2021 Share Posted February 3, 2021 You do not say witch carb you are using I use an AMAL concentric on both cubs Both engines are move to the left One uses the cub manifold Yes the cable clears the frame but only just The other has a made up manifold that makes the carb more upright and is much longer and has more of an offset Quote Link to comment Share on other sites More sharing options...
Robboshome Posted February 3, 2021 Author Share Posted February 3, 2021 I have an Amal concentric that I want to fit was your manifold from another bike or manufactured by yourself ? sure there must be something out there just trying to shortcut if anyone knows! Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted February 4, 2021 Share Posted February 4, 2021 Try a carb spinner for a pit bike. You can move the carb to different angles with one it might be a cheap option to modify it to fit your carb. Quote Link to comment Share on other sites More sharing options...
Robboshome Posted February 4, 2021 Author Share Posted February 4, 2021 Wow bloody genius creepytheclutchmaster i will try that ? Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted February 4, 2021 Share Posted February 4, 2021 I had a similar problem, iv fitted a yx140 engine in a bultaco sherpa rolling chassis and the tank was fouling the throttle cable. The spinner was only about 6 quid from redcircles easy to modify as well being soft alloy. Quote Link to comment Share on other sites More sharing options...
Robboshome Posted February 4, 2021 Author Share Posted February 4, 2021 Thanks very much for your info i am currently restoring a 1934 Ford truck and building a tiger cub trials which needs everything modified not sure which is the most brain taxing at 60 years of age ? Quote Link to comment Share on other sites More sharing options...
