August 15, 20215 yr Hello In my 250 Alpina (115), I am looking to install the rear brake switch in the swingarm... What do you have, pictures ? Thank you Divouneh
August 23, 20215 yr The original rear brake light was powered off the ignition coil and used a resistor in case the filament burned out. Without the resistor the brake switch became a kill switch every time you stepped on the rear brake.
October 9, 20215 yr I guess with LEDs not pulling as much power you could use them to run it off the lighting circuit with no ill effects (?)
October 9, 20215 yr Author My Alpina will be equiped with a 12 volts system and electronic ignition...
December 5, 20214 yr Author I found this idea, I will try ... Just to be legal, I am always using the front brake first 😏..
