August 21, 20215 yr I have a Beta 200 EVO that needs a new chain, but it’s 101 links with a half link. I can’t find one anywhere, apart from Beta uk, but the chain is £80 plus postage. Can anyone suggest a supplier or will I need to buy a chain plus half link and rivet it to the chain? Â
August 21, 20215 yr Buy any length chain longer than 101, a half link and an extra split link. Cut the chain to length, use the split link to connect the half link and then use the other split link (comes with chain) to join the chain ends. You do need to buy the correct split link and half link (Same manufacturer and chain type) Chain splitters are around £15. I still use one that came with a bike my grandpa had in the 1920s!
August 22, 20215 yr https://www.inmotiontrials.com/product/regina-520-gold-link-trials-chain/  https://www.inmotiontrials.com/product/regina-520-trials-chain-12-link/  https://www.inmotiontrials.com/product/chain-link-extractor/ Assuming it's 520 chain ? Regina chain links can be reused , when you split the chain the half link can be attached meaning you only have one link. Chain is out of stock, give them a phone.
August 22, 20215 yr Author Thanks for the feedback. I’ll try to order the chain and links (seems to be a shortage of parts at the moment).
August 23, 20215 yr On 8/22/2021 at 10:09 AM, Kpmpap said: Thanks for the feedback. I’ll try to order the chain and links (seems to be a shortage of parts at the moment). Off Road Moto, Blyth ?
August 24, 20215 yr Author Thanks for the feedback. I’ll try to order the chain and links (seems to be a shortage of parts at the moment).  I’ve ordered replacement parts from Motomerlin, cheers.
