April 30, 20224 yr I have a 2021, which is different, so can’t say for sure. I believe that they moved the map switch, and indicator light, to its own housing on the left side of the handlebars. I believe that is what you are looking at.
May 2, 20224 yr Author On 4/30/2022 at 9:28 AM, dgshannon said: I have a 2021, which is different, so can’t say for sure. I believe that they moved the map switch, and indicator light, to its own housing on the left side of the handlebars. I believe that is what you are looking at. I found out later that this button is the engine brake button.
May 5, 20224 yr Author 2 hours ago, micm said: 배터리 재생, 엔진 제동도 제공 Thank you.But it's hard because it's the button position when I press down with my thumb
May 5, 20224 yr 9 hours ago, jacsal said: Thank you.But it's hard because it's the button position when I press down with my thumb Agreed, that looks really awkward to use. On my '21 I use a small lever place directly under the clutch lever.
May 17, 20224 yr On 5/5/2022 at 4:44 AM, trapezeartist said: On my '21 I use a small lever place directly under the clutch lever. What lever did you use? The factory add on?
May 18, 20224 yr On 5/17/2022 at 3:56 PM, dgshannon said: What lever did you use? The factory add on? I bought it from John Uyehara in Hawaii. I think the basic lever is probably intended for a quad bike throttle, or possibly a very short lever for a pushbike. Then he's put a magnetic microswitch in where the cable would go and attached a lead with the correct connector for the bike. $50 plus postage I think, which worked out to about £50.
January 23, 20233 yr On 5/18/2022 at 2:27 PM, trapezeartist said: I bought it from John Uyehara in Hawaii. How do you go about buying one? Is there a web site?
January 25, 20233 yr On 1/23/2023 at 12:24 AM, mcman56 said: How do you go about buying one? Is there a web site? I don't think so. His business is Ka Uila Motors, but I think you would find him most easily on https://www.facebook.com/groups/684403832119578.
