August 8, 20224 yr hi all, i have a 2019 beta evo that id like to repack the silencer on but it looks like you need a special tool to undo the screws at the end with, looks like a star drive but with a pin in the middle, could any tell me where i can get 1 from
August 8, 20224 yr Good evening, I removed mine with the old bodge with a hammer and a chisel, you could also grind a slot with a dremel . I then replaced them with some sensible hex heads. Good luck.
August 8, 20224 yr 1 hour ago, nickmeredith said: hi all, i have a 2019 beta evo that id like to repack the silencer on but it looks like you need a special tool to undo the screws at the end with, looks like a star drive but with a pin in the middle, could any tell me where i can get 1 from Sounds like a standard security torx here in Canada, not sure where you are?
August 8, 20224 yr Author 8 minutes ago, Glayne said: Sounds like a standard security torx here in Canada, not sure where you are? Thanks pal , thats exactly what they are , just found a set on amazom for a fiver
