betarick Posted February 27, 2006 Share Posted February 27, 2006 Has anyone had any bother with these forks leaking from seals? I have replaced seals twich now and also replaced dust seals. There is no play in forks and no marks on stancions. Any help would be great i have rung lampkins and they said i need new forks which are not cheap. Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted February 27, 2006 Share Posted February 27, 2006 My new forks seals continued leaking on my old Gasser and i was told that there may be too much wear and slack causing the sliders to be loose (side to side) therefore opening the seal. I eventually fitted seals with a smaller inside diameter(.5mm)which cured the problem.This may cause the forks to be not so smooth. Try www.eabs.co.uk. They are very helpful and cheap and have every bearing and seal you could possibly want(not all on the web site). Are these forks upside down units that were fitted in Aprilia climbers? If so i have the parts sheet for them . If you want a copy then just message me privately with your email address and ill scan it and send it by email. Quote Link to comment Share on other sites More sharing options...
betarick Posted February 27, 2006 Author Share Posted February 27, 2006 The forks are not the upside down version .Thanks for website link i will have a look Quote Link to comment Share on other sites More sharing options...
steve shakeshaft Posted February 28, 2006 Share Posted February 28, 2006 I can't imagine you definately need new forks. Even if there is excessive looseness in the sliders, you can replace bushes in them normally. If there aren't any bushes, a good restorer could still bore the sliders and bush them for you. HTH Quote Link to comment Share on other sites More sharing options...
