March 28, 20233 yr During my clutch inspection I found two steels that had lips along the outer perimeter on one side that the adjacent friction fits nicely into. These aren’t mentioned anywhere in the manuals I found, do they go in a special location in the stack? The frictions were all within spec so I reassembled as it came apart and flipped the spring washers so the raised area was nestled inside the spring, lowering the effecting preload pressure on the springs. Clutch is a lightswitch, I’m hoping to get more progressiveness in its action…. Thoughts? Skiddy
March 28, 20233 yr My 2014 Factory model came with those. The parts list shows them in positions 2 & 4 of 6. There was something else different about the clutch too, maybe the hub. I could never figure out what the additional features were supposed to do. The clutch did not work any better or any worse than any other Beta clutch. plate https://trialworld.es/tienda-trial/en/clutch-trial/2668-beta-evo-factory-steel-clutch-disc.html
