July 12, 20242 yr I bought what I think is a 2002 Gas Gas TXT 250. I know the year is correct but they also made a TXT 280 Pro in 2002. How do I tell which model I have. Its a fixer upper so got no documentation or and info on it. Thanks for any help.
July 13, 20242 yr Throw up a photo and the hive mind will be able to tell you. Quick reference - there are other differences but this is quick: TXT model 2002 and before has a longer shift lever 2002 and later Pro model has a shorter shift lever Also frame differences Edited July 13, 20242 yr by zippy
July 17, 20242 yr Author It does have the short shifter . So any other things that would give me an idea what model it is?
July 17, 20242 yr You have the TXT model before the Pro model came out. Frame matches the frame in the first photo I posted, look closely at the footpeg area. Also The exhaust header where it enters the midbox is horizontal, the Pro in angled at that point. The radiator on yours is "inside" the frame, the Pro the radiator sides are visible. 250cc vs 280cc, The Pro model has a number in the casting of the cylinder. Shifter side, 25 = 250cc; 28 = 280cc I don't know if the TXT model also has that number in the cylinder casting.
July 17, 20242 yr The TXT also lacks the Pro's diaphragm clutch and patented "4 gear-pairs provide 6 ratios" gearbox.
July 18, 20242 yr Holy smokes that looks familiar, I was going to ask if that was my old bike but I think I had the pipe and silencer ceramic coated. I thought mine was a one off with the green rad guards, guess it was stock? Mine was an TXT 02Edition 250. My rear fender and air box cover even mis matched a bit like that one seems to, I wonder if that is stock as well? Are you in Canada? is that my old bike? looks like a washer welded to the kickstand like mine had as well? That 02 was really good to me, I thought I had downgraded when I first got my 2012, I'm used to it now.
July 19, 20242 yr Author 7 hours ago, Glayne said: Holy smokes that looks familiar, I was going to ask if that was my old bike but I think I had the pipe and silencer ceramic coated. I thought mine was a one off with the green rad guards, guess it was stock? Mine was an TXT 02Edition 250. My rear fender and air box cover even mis matched a bit like that one seems to, I wonder if that is stock as well? Are you in Canada? is that my old bike? looks like a washer welded to the kickstand like mine had as well? That 02 was really good to me, I thought I had downgraded when I first got my 2012, I'm used to it now. Did you sell it to a fellow named Pat ?
July 19, 20242 yr ... Don't remember... Names...Hmmmm... I'll have to look a ways back. I sold it in May of 2020
July 24, 20242 yr Author On 7/18/2024 at 10:05 PM, Glayne said: ... Don't remember... Names...Hmmmm... I'll have to look a ways back. I sold it in May of 2020 Kamloops BC
July 24, 20242 yr Ha! Funny, I bought mine in Kamloops, lol sold it to a guy named Jeremy in ?West Kelowna if I remember correctly? I did have the exhaust and silencer painted black, the rest looks *really* familiar!
