March 27, 200620 yr Think I may need to bleed the clutch on my SY. Only had time for a quick look at it, has anyone done it?
March 27, 200620 yr If its the same as the sherco and gas gas set up then yes. Reverse bleed from crank case with syringe same as brakes. think the rypusa website has details.
March 28, 200620 yr Author Well, after stripping the bike it seems that there is no easy way to bleed the clutch, not that I can see anyway!! Bummer!
