trapezeartist Posted February 17, 2025 Report Share Posted February 17, 2025 I broke the lever lug off my front brake master cylinder at the weekend so I need a new master cylinder. Are AJP and Braktec the same thing? I thought they were different but I've seen them advertised as the same. Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 18, 2025 Report Share Posted February 18, 2025 Good trick question. Ajp went under. AJP made a better product. But Brakteh uses thier design in a different body. I use the old large body AJP. Mainly they are more dependable. But they use the same pistons more or less. The Braktec feels smoother when bled well. But I still get a firmer brake overall with the ajp. 3 Quote Link to comment Share on other sites More sharing options...
lemur Posted February 18, 2025 Report Share Posted February 18, 2025 Over the years there were 2 different sized banjo hose fittings and the handlebar mount went from two bolts to one bolt with a hinge. You will want to make certain your hydraulic fittings are the same or you will end up replacing the entire front brake assembly. 1 Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted February 18, 2025 Author Report Share Posted February 18, 2025 Thanks chaps. But it wasn't intended as a trick question, Lineaway. Quote Link to comment Share on other sites More sharing options...
lemur Posted February 18, 2025 Report Share Posted February 18, 2025 It is a trick question from the aspect that Brembo bought J.Juan which bought Braktek subsequent to their purchase of AJP so yes; there are a whole bunch of different model brakes all made virtually by the same company. Photos are the best way to tell them apart 😕 2 Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 21, 2025 Report Share Posted February 21, 2025 Gas Gas announced a recall on all the newer mx bikes. The Braktek caliper has issues. Go figure. Quote Link to comment Share on other sites More sharing options...
