Clutch engagement
Dirt-preacher
Good quality gear oil to suit a trials bike.
Moving the lever location on the bars so you are pulling further out on the lever.
Depending on how low low hours is 2017 is also old enough you might want to consider filing any ridges that exist in the clutch basket tabs from wear with the clutch plates.
The other replies are spot on, but the top hat washers on the springs on some beta models are also worth checking. They can be fitted either way up for more or less preload which makes a big difference to how the clutch feels. While you're in there there's a shim and a spec for the clearance at the end of the push rod, it's worth checking while you're on but it mainly affects drag.
  • 2 weeks later...
Two very good points that I had forgotten.
